300ex PROBLEMS
Old Nov 9, 1999 | 09:24 PM
DG_300EX's Avatar
I am having a problem with my 98 300EX. I think it is the axle bearings, but i am not 100% sure it might be the disk brake there is definatly something grinding. It was weird i was riding along and all the sudden out of nowhere there is this grinding noise so i stoped and i figured it was the sporket or something toching the skid plate but, nope i slowly rode it home and i am wondering what to do. I am taking it to get it serviced in a few days, but i can't go without riding for that long, but i may have to!
Old Nov 10, 1999 | 05:37 PM
The400EXman's Avatar
It sounds like your back brake pads are worn out. I hade the same thing happen to me. on a 98' 300EX too, how odd. Don't ride it until you get new ones becouse the metal rubbing will grind down your disc rotor.
Old Nov 10, 1999 | 07:20 PM
4trax300ex's Avatar
i had the same problem first i thought it was pads so i got new ones the noise was still there so i found out the axle was wabbleing and the disk was hitting off the left of the caliber
T.J. Flynn Honda 300ex - stock but not for long
Old Nov 10, 1999 | 09:58 PM
CB400EX's Avatar
their are 2 bolts that hold the rear brake caliper on. remove them and set the caliper on the swingarm and roll the quad back and forth. if the noise stops its the brakes if not its the bearings probably. hope i could help. CB400EX, 99 400EX
Old Nov 10, 1999 | 10:37 PM
mberry's Avatar
I'm betting it is the axle bearings - I had the exact same symptom on my 250R shortly after I bought it. Don't ride it till you are sure - you could easily go from needing a new set of bearings (about $50) to needing a whole new axle carrier AND bearings (anywhere from $150-$350). Another check for the bearings - put rear of bike on a stand and grab both back tires. Try to wobble the axle in the axel carrier. If there is any movement you'll need at least new bearings and seal.
good luck!
Old Nov 11, 1999 | 07:35 PM
DG_300EX's Avatar
IF It were the axle bearings wouldn't the axle have a bit of play to it i am going to go remove the bolts on the brake caliper and see if it is the brake and i will tell u tommrow!!!
Thanks
but plz kepp sendin your replies!!!
Old Nov 17, 1999 | 05:45 PM
DG_300EX's Avatar
I JUST WANTED TO SAY THAT I GOT IT FIXED AND I HOPE THAT I NEVER HAVE TO DO IT AGAIN IT WAS MONEY THAT I WANTED TO SPEND ON UPGRADES!!!AND IT WAS THE AXLE BEARINGS!!
PARTY ON!
RIDE RED OR GO HOME!
DG_300EX
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
