465ex ????????????
Old Feb 9, 2002 | 03:46 PM
Mr350X's Avatar
I wouldnt recommend a 426, as the stock sleeve is used and gets very very thin when bored out that much.
-Matt
Old Feb 10, 2002 | 02:49 PM
TrX465's Avatar
this is what i have done
mods : je 92mm piston 13:1 comp modded by sparks ,sparks custom sleeve *not stroked* ,hot rod , fcr 39 carb with alcohol,titanium retainers, valves, sparks cam, ported and polished with a flow meter, lrd big bore exhaust ,sparks heavy duty cam chain, trued and welded crank (shaved down incase i decide to stroke to well over 500cc ), lightned flywheel, hardened rockers , hinson clutch crap,kevlar disks,motors been polished. i have other engine stuff as well and the frame is floresent yellow with majer racin plastic custom painted midnight blue, battery was moved to front , street tires *grooved* ,18in turf tamers, dg alloy nerfs,cascade block off, no front brakes,one custom head light , i owned 2 other kits a 416, and a 440 the 440 snapped a rod in half, and came out the case causin me to buy new cases.....
Old Feb 10, 2002 | 03:41 PM
MattFisher's Avatar
<< Yea i would love to have a 250R soo bad and get a 330 kit for it but Around here theres no place where i can get a good used one . >>
Try the cycle trader www.cycletrader.com E-bay, and all the message boards. Plan on spending quite a few hours in front of the monitor, and take good notes. I live in California, and bought my 400EX from Ohio. Even after shipping, I saved quite a bit of money. Forward Air is the least expensive way to ship that I've found. Under $200 for mine.
There are lots of 250R's out there, you just have to look.
Bakobanshee
Dunes and Dune Machines
44
Apr 28, 2004 09:17 PM
Sandragggen
Apr 1, 2004 09:03 PM
lancer202
Jan 22, 2003 03:02 PM
TopDawg
Oct 27, 2000 08:44 PM
Berch
Sep 4, 2000 01:25 PM
