porting
Old Feb 15, 2002 | 10:10 AM
250argh's Avatar
why would someone want to give away their numbers? that would be a complete waste of r&d time & money!! one wouldn't be in business too long operating that way! that's why people pay for the premium port job, and then steal the numbers to try and wack out themselves with their dremel from home depot!!
Old Feb 15, 2002 | 07:50 PM
trapperb1's Avatar
Rick MacDizzy not only tells you his numbers for porting, he shows you the pictures on how to do it. He still remains busy.
The guy that works on cylinders for all the shops around here will do the porting for you, and saves you the money by not polishing the transfer ports. They don't need polishing, just a bit of smoothing-out and just about anybody with a dremel can do it.
Old Feb 15, 2002 | 08:39 PM
OregonMXracer's Avatar
OK, I probably sound like a moron, but how do you know how much material to remove? I have checked out MacDizzy's site about porting but I guess I'm a moron. Someone elaborate on porting for me.
Old Feb 16, 2002 | 01:31 AM
Blaster668's Avatar
All the numbers really tell you is basically where the powerband will be. If you buy a cam for a car, would you buy it without knowing the "numbers". Those are basically the same #'s as a port job uses. The engine builder can still have lots of little secrets, like port angles, and port widths, auxillary ports, and boost ports, how much is taken from the transfer ports. None of those things are told in the simple numbers. People should actually be more informed when they get a port job. Macdizzy's site is awesome and I reccomend that anyone wanting to get a port job should check it out.
Old Feb 16, 2002 | 11:27 AM
  #15
Dill's Avatar
Rick does not give his porting specs. Hell he won't even post the dyno graphs that they ran on the 310cc cylinder they tested with the various pipes. Some technology exchange.
franklyme
Oct 21, 2016 07:18 PM
QuadRiders
Oct 22, 2015 04:13 PM
Brandon400
Sep 5, 2015 08:44 PM
