front or back sprockets
sorry buddy, you got yourself all backwards, the less teeth you have on the rear the faster you go, the more teeth the lower geared it will be. now if you put a bigger sprocket on the front that is going to make the most difference, most ppl just go up on tooth size in the front and a couple down in the rear if they want speed. thanks
