Cobra or DG?
I knwo i know!! Bouth are not the best !! and thats buy far!!But what i want to know is!witch one would u guys get!?? and witch one is better !! and the loudest one!! Because I DONT want the loudest one!! 1)cobra JET.2)cobra alum.3)DG RCM.4)DG krome power!! witch one is best?
haven't we already been over this? don't get either one. just save up for a little while longer and get a real exhuast. even if you need to replace a broken one or somethin just buy a used stock or even a used aftermarket.
Who cares. You are telling him what to spend his own money on ha. I had a cobra on my Mojave, (Now I have FMF) When I first got the cobra a week later the complete core just blew out, snaped off the bracket holding it on.
DG pipes may not perform good, but the seams, finish on aluminum RCM are absolutley flawless, and they are strong fit is great too. That's my experiences with the DG pipe I had on my YZ80. There's no way I'd choose Cobra over DG.
Oh with the DG pipes, there isn't a difference between Krom Power and RCM, just that Krom Power is steel construstion and is chrome plated. the RCM type are either steel or alloy. Go with the Alloy RCM, because the Krom power will only look good for the first few rides. It will blue real fast also water and Chrome don't mix.
Both are totaly junk, rattletrap, way to loud, and usualy don't last..My friend went through 2 DG pipes on his CR....burnt right through the POS pipe, Cobra is just as bad if not worse, if you wase any money on eiter one of those pipes you must be numb...
i have a dg pipe on my 300 and i like it. i didn't buy it it came on my 300 when i bought it so i just left it on. i could actually tell a difference from the stock pipe and the dg. i think the dg sounds nice too. my dad has the krome power and it has already turned blue. i have the steel one and if i were you i would just go with it cause you can at least paint it when it starts to look bad.
Bm400ex
Jun 22, 2015 09:16 AM
