Break in Time.
Old Mar 23, 2000 | 10:20 AM
DanHonda300ex's Avatar
What is the proper way to break in your bike.
I just bought a 2000 400ex. =)
Old Mar 23, 2000 | 10:49 AM
THEXOTIC1's Avatar
I was told to keep it under 1/4 throttle for 2 tanks of gas then gradually start opening it up after the 4 th tank of gas change the oil and then you can really open it up
Thats what a honda dealer told me to do does anyone else have any other suggestions
Old Mar 23, 2000 | 04:24 PM
jakeh's Avatar
I'd follow the owners manual on the break in!
Old Mar 23, 2000 | 05:49 PM
Moses's Avatar
Here's the deal:
Tank #1. Do not hold at constant engine RPM. Always move the throttle around.
Tank #2. Beat your 400ex loudly. It wants it.
Change oil.
It's a Honda, for Pete's sake. 4 tanks under 1/4 throttle? C'mon. You probably don't even need to break it in. The best way to do it would be to put the smack-down on it over a motocross track. It's not a damn Polaris.
Old Mar 23, 2000 | 06:44 PM
drlaney's Avatar
Use conventional oil during the first 30 or so hours. Only then should you consider using synthetic oil.
Synthetic oil performs so well that rotational surfaces may reach their polished stated before the "bedding" process is complete. Bedding is the process where normal imperfections betweeen mating surfaces (crankshaft to rod bearings for example) are worn away. When synthetic oils are present during the break-in period, these surfaces will often wear to their final polished state with the imperfections still present.
If you want to make a perfect engine, you'll have to make it in outer space away from gravity.
Old Mar 23, 2000 | 07:11 PM
400exalltheway's Avatar
the dealer i got it from told me to ride it 10 hrs. then bring it back so they could tear the engine down and check everything to make sure it was ok then just do whatever i wanted to it
Old Mar 28, 2000 | 08:08 AM
puddding's Avatar
the honda dealer i deal with over here in NZ and i both came to the same conclusion......
running any honda in: drive it like yah stole it
if not it will always be slow, this threoy only applys to hondas though, not recommended on other makes. my 250x is like that......good bike.....still original engine
we ran my '90 300 4x4 in the same way...did 8500hours before sale (it was a dairy farmers bike- did a lot of idling following cows, an heaps of towing), did one set of compresion rings, reconditioned both diff...we adventually wrote it off....hit it with a digger stacking forage crops..fixed it...still going!!
Scooter's Shop
Oct 9, 2015 02:09 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
black798
Sep 9, 2015 07:42 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
