List Your Rancher 350 Troubles here....
Old Dec 10, 2009 | 06:29 PM
  #41
mtacsik's Avatar
Default Yep
I bought mine used less than a 100 hours on it. I have the same problems, did the angle sensor fix it? I'm about ready to build a pernament shifter for the foot. If the angle sensor did not fix it what did you do to fix it?
Old Dec 10, 2009 | 10:57 PM
  #42
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Original post is 7 years old! I had to clean my carb once....bad gas.
I always warn prospective guyers to avoid the ES!
Old Dec 13, 2009 | 06:44 PM
  #43
oldstyle's Avatar
The only problem I've had was the foot brake pedal siezed on its pivot. I've seen this on three Ranchers.
Old Dec 14, 2009 | 08:52 AM
  #44
MUd&ROX's Avatar
ha ha thats good. I spent about an hour yesterday with a gear puller tryin to get the foot brake off the peg! get it off sanded the peg down to bring a shine smeered it with green grease and put it back together! works like a charm......for now!
Old Oct 11, 2011 | 02:38 PM
  #45
rancher0418's Avatar
I have a 02 rancher 350 that my son rode alot till he wore it slap out. I recently had the cylinder sent off an reworked. Before it went down the clutch didnt seem to work properly. Once I had it down I replaced the clutch and it is still doing the same thing. I have taken it down several times and still the same problem. What it is doing is it constanly pulls, I tried adjusting the clutch and there is no happy medium with it. It also makes a winding down sound when you turn the engine off and it was doing it prior too. Its like something stuck and I can't seem to find what it is. Oiled the clutch like the book says and bought another off ebay. What else can it be any suggestions?
Old Jan 12, 2012 | 08:38 PM
  #46
loweredge's Avatar
Default torque specs???
I have a 2005 trx350 rancher and I need to find the torque specs for the rear gearbox... Does anyone know where I could possibly find the specs? I just don't have the money to spend on a $60 owners manual. I bought that sucker off the show room floor. It's been the best investment I've made for my family farm... Any help would be greatly appreciated.. Thank you.
also I need front tires for it. I have a brand new set of Polaris tires still with nipples on them... Different size than the rancher of course so not inter changeable... If anyone knows someone or they themselves have new tire for a rancher and have a use for these tires I would be willing to trade them even up...
Just a side note... the torque specs are what are important right now... thanks to everyone...
Old Oct 23, 2012 | 03:34 PM
  #47
bigcountry78's Avatar
I had a 2000 Rancher 4x4 ES, I got it new and had it for about 10 months. During that time in was in the shop 5 times, all for ES related shifting problems. The last problem, I was told, was a cracked shift drum. After I got it home from that I sold it and bought a 2000 Big Bear. Rancher had roughly 1500 miles on it when I sold it. All repairs were luckily done under warranty, but I hated hauling it 45 miles one way to the dealer. Also had the recall, some type of suspension mount if I remember right.
Old Jan 16, 2013 | 03:48 AM
  #48
Tpl1963's Avatar
03 350 ES 4x4. Great bike! No problems that weren't direct result of extreme abuse!! Love it!!!
Old Jan 24, 2013 | 02:11 PM
  #49
rwelch2210's Avatar
Default 2001 rancher 4x4 es not shifting
Just got this 2001 and all was well but now it will not shift at all. It is in nuetral and will turn over but the digital display has the line across it..BOTH the neutral AND the reverse indicator lights are on at the same time. I tried rocking it...i got the manual shifter out and when i change gears its working because it wont turn over when not in N...but dotted line is still on the indicator...and both indicator lights remain on regardless of what gear its in...thinking its a short...any ideas?where to start?....this is my 1st atv...
Old Jan 24, 2013 | 06:17 PM
  #50
Tpl1963's Avatar
Might check the 22 pin connector under the right side rear fender...take itapartand blow it out good. Fixed mine when it did tgat
