Rancher- location of oil filter and manual start
Old Nov 26, 2002 | 05:41 PM
CS's Avatar
CS
Default Rancher- location of oil filter and manual start
I just bought a used Rancher and don't have the owners manual. I've been pokin around but couldn't locate the oil filter or the manual recoil start. Anyone point me in the right direction(s)?
Thanks
Old Nov 26, 2002 | 10:56 PM
hounddog's Avatar
If it's the same as my 2002 Rancher, the oil filter is on the right side of the engine (towards the front) under a circular plate with three 8mm bolts on it.The filter is kind of spring loaded, so be careful when you take it off. The recoil start is under the removable plastic trim towards the rear of the engine on the same side.(Kind of where your right heel would be while riding) Hope this helps!!!
Old Nov 27, 2002 | 12:54 AM
CS's Avatar
CS
Got it, thank you. I guess I need more light in my garage, I can't believe I didn't notice the pull start.
robj
Jun 15, 2015 08:45 PM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
jayking232003
Jun 9, 2015 02:54 PM
1000gade
May 27, 2015 12:37 PM
