starting a flooded engine
Old Feb 29, 2016 | 02:25 PM
Sounds like the over flow/drain tube. If it's leaking usually the needle and seat are worn,float level off,etc. This would probably help.Carburetor Carb Rebuild Kit Yamaha YFM80 Badger 1992 01 YM80R Raptor 2002 08 | eBay
Old Feb 29, 2016 | 06:44 PM
_zero_'s Avatar
Alright thanks I'll give that a try
Old Mar 1, 2016 | 02:57 AM
If it has leaked enough fuel into the cylinder to cause a "hydraulic lock" of the motor, fuel will have run into the crankcase as well and diluted the oil, if the oil level has risen and smells of fuel, change it before using the bike again.
tiresharkdbb
Sep 3, 2017 02:06 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
1000gade
May 27, 2015 12:37 PM
Max6x6
Oct 1, 1999 11:36 PM
dunc_n
Aug 26, 1999 09:32 PM
