Wheel Bearing
I have to replace a front wheel bearing on my Forman 450s. Does anyone know how tight the castle nut has to be tightened??? Is there a torque spec, if so what is it??? Any other tricks I should know about??? ( I have had the front apart B4 to inspect the brakes, but now I'd like to be sure on the specs.)
Thanks in advance.
Thanks in advance.
Whenever I change a bearing I tighten all the way and then slack it off until the wheel turns freely with no play. I spin it again and then do it again to make sure there is no play and the bearing is not binding. Slip the cotter in and you are done.
Cantbuytime
Aug 16, 2015 09:13 PM
