400EX TURBO ATV
Old Apr 30, 2003 | 03:23 AM
AZBIGDADDY's Avatar
Default 400EX TURBO ATV
This has nothing to do with ATV's, but here is a link to another project I did. www.nightlifelimobus.com
We took a 40ft deisel pusher RV and rebuilt it from ground up, into a custom limo bus.
I love bad *** toys and had to share this one with everyone, sorry if i affended anyone because of it!
Turbo charged jet skiis, snow mobils? MAYBE!
Thanks again!
AZBIGDADDY
Old Apr 30, 2003 | 03:12 PM
LinkX's Avatar
I'm drooling! We just built a 450 Foreman 4x4 with our Link-X front suspension. You'll see this in the magazines in 2-3 months.
We plan on doing a sport ATV and have been thinking of buying the new 700. A turbo 400ex would be even better.
Is there a turbo 'kit' for this?
Cheers,
Todd
www.Link-XSuspension.com
Old Apr 30, 2003 | 03:14 PM
LinkX's Avatar
I just read your post again with the name of the kit...
Old Apr 30, 2003 | 03:52 PM
hayve's Avatar
link x, could you post some pictures please because theres nowhere round here that sells the magazine, the turbo 400ex is wew nice, say if you was to sell it, how much would u ask, im just enquiring
Old Apr 30, 2003 | 08:54 PM
  #15
TyreSpinner's Avatar
Wow, thats some nice tuning.
Good luck trying to keep those front wheels on the ground and your grab bar off the ground.
[img]i/expressions/face-icon-small-smile.gif[/img] Sweet. Finally a 400ex with *****. [img]i/expressions/face-icon-small-smile.gif[/img]
Congrats
Old May 1, 2003 | 02:08 AM
  #16
AZBIGDADDY's Avatar
Garret will be selling the KMS base system for $2,700. I can get one for a little less....
Here is a picture of the other side of the quad (see turbo, pipe work, etc.) http://400exturbo.50megs.com/index.html --->hope you like it!
F.Y.I.
There is alot more to the story here then i can tell right now, though I will share more info in the next couple months.....
AZBIGGDADDY! Text
Old May 2, 2003 | 10:38 AM
  #17
DSAPP's Avatar
how does an intercooler boost horsepower that much???
Old May 2, 2003 | 04:57 PM
  #18
bassetboy55's Avatar
its required that you run an intercooler...a turbo works similar to an after burner, running off the unused combustable air in your exhaust, and re-routing it back into the combustion chamber....if you didnt have an intercooler the exhaust that would normally pass through the intercooler would be wayyyyyyyy too hot.
Old May 2, 2003 | 05:16 PM
  #19
Raptoryfn660r's Avatar
RIP Dear Friend
I am no expert on this subject while it is better when turbocharged to
have an intercooler because the forced air is cooled and the air is more
dense thus higher horsepower I don't think it required.
The early turbocharged cars such as the 80-81 Trans AM had no intercooler
nor did and I can't remember the year off hand one of Honda's mid to late
eighties street bikes came from the factory turbocharged and had no intercooler.
I remember one of the problems of early turbochargers was the bearing would cook because the user would shut down the engine while not letting the turbocharger to spool down. The oil remaining around the bearing would coke. Years ago I was told to let the engine idle for a minute or two so the problem wouldn't occur. Some of the early turbo motors also required straight 30 weight oil because of the mentioned problem.
ChetRacer[img]i/expressions/face-icon-small-cool.gif[/img]
Old May 2, 2003 | 05:17 PM
  #20
AzRaptor's Avatar
Actually, you do not re-route the exhaust back into the combustion chamber, you harness the exhaust energy with an exhaust housing that is mated to an air compressor via a common shaft. A by-product of compressing air is heat, therefore the intercooler is used to remove some of the heat that was created by compressing the air. The cooler the air the denser it is, the more air you cram into the cylinder, equals even more HP. Although an intercooler is not necessary, you can get into a situation where you can negate the effects of the boost pressure due to the heat you create. Pretty cool stuff!!!
