400EX popping through carb
Old 05-06-2003, 05:17 PM
dbeck's Avatar
Default 400EX popping through carb
A friend has a 400EX. His exhaust header pipes glow red and the engine is firing back through the carb. Usually that means the valve timing is off or the valves need to be adjusted. But I guess it has done this since it was new and the valves are adjusted correctly. Anyone else run into this?
Old 05-06-2003, 08:57 PM
dzzy's Avatar
Yeah, or turn the mixture screw out a bit. The backfiring usually indicates a lean condition. As far as the pipes glowing red, it seems like a bad thing but have noticed the same myself on several quads. Also make sure your idle isn't set too high.
Reactant
03-30-2022 02:08 AM
95wolv
07-21-2015 12:25 PM
ghost civic
07-19-2015 10:13 AM
yambam13
07-04-2015 01:49 PM
Quick Reply: 400EX popping through carb
