Hunting, Trapping, Game Management Discuss Bow and Fire Arm Hunting.
Finish mower not cutting very good
Old May 18, 2004 | 10:29 AM
Chawness's Avatar
Default Finish mower not cutting very good
I must have did something wrong when I sharpened the blades on my finisher mower. The whole yard looks "choppy" or uneven. It was better before I sharpened them! When I sharpened them last summer it did great, could I have put the wrong angle on them or something this time? Or could it be a belt slipping??
Old May 18, 2004 | 11:51 PM
JohnO's Avatar
Is this the first mowing you've done with that mower this year? Might check your tire pressures - when I see an uneven yard, usually one tire is low on air.
Old May 18, 2004 | 11:55 PM
Raptoryfn660r's Avatar
RIP Dear Friend
Is your deck level?
Old May 19, 2004 | 02:19 PM
LEP7MM's Avatar
Did you put the blades on upside down? I have heard of that happening several times already this year.
Old May 19, 2004 | 08:45 PM
trailride's Avatar
I have a pull behind mower and it does that when the deck is clogged with grass and if you mow too fast or if you try to mow too much at once. Only mow about 2" at a time or you will have to go over it twice . A new belt will help also. Just take your belt off and go to a auto parts store and find one. Its alot cheaper there.
Old Jun 8, 2004 | 01:53 PM
Chawness's Avatar
Ok guys, I have checked all that and it all looks good, the tire pressure, the deck level, the blades on right. I think the problem is when I sharpened the blades I put the wrong angle on them. I looked at a new set of blades and noticed the angle of the cutting edge wasn’t as sever as mine. For instance the angle on the new blade looked about like a 20 degree, were mine is more like a 45.
Would this cause a problem?
coldnorthpol
Jul 14, 2015 11:22 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
tmoose
Jun 30, 2015 08:28 AM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
