Ready for winter (plow installed)
Well, finally got my WARN 54" plow installed on my Eiger. Take a look at the pic. The plow is cleaner than the ATV.
I'm ready for the hard winter everyone keeps saying we are going to have.
I paid $345 shipped for the blade, plow tube and mounting bracket from www.sportztrailers.com. You can find them on ebay too. They did not have the mount for my ATV, but I called them and they were able to get it and it was cheaper than ordering directly from WARN.
You install the mount under the ATV it it stays there. To connect the blade and plow tubes, you attach to the ATV with two pins with clips and hook the winch line up by tightening one bolt. To remove, just loosen the winch bolt and pop out the two pins under the ATV. Pretty simple.
I've got a Moose Country Plow on my Rhino and just put another one on my 09 750 Kind Quad efi. These plows are great and can do more work then my old cycle country plows I had in the past.
I have the swisher blade. It's all metal, has held up pretty good. Great for pushing brush piles and loose dirt around. I bought it to push snow, and then we haven't had snow worth pushing for five years.
It does absolutely kill your ground clearance, though...
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
