Newbe, 07 Sportsman 500 x2 Looking for help
Old Aug 29, 2009 | 06:19 PM
medicman1855's Avatar
Default Newbe, 07 Sportsman 500 x2 Looking for help
Joined this forum because it looked like it could be really helpful. Piece of wood poked hole in oil box. Ran out of oil & didn't know it. Slowlyl died, now will not start. Looking for suggestions on where to start.
Old Aug 29, 2009 | 08:48 PM
08700efi's Avatar
so did you actually end up driving the engine with out oil in it for any distance with out knowing it? if so there could a lot of issues, guess you could start with a comp check but there is no way of knowing what the inside looks like, fill it back up run it for say a half hour and drain the oil into a clean container and see what it looks like, it may look metalic with alot of silver in it from the parts wearing while the engine was ran with out oil in it. if it wont start im guessing it may not have any compression.
Old Aug 29, 2009 | 09:28 PM
Default Checked compression
Compression gauge said about 50 psi and didn't leak off much. Don't know how much psi I should have. Replaced oil box, put in new oil. I got spark but still no start.
Old Aug 30, 2009 | 12:31 AM
faruquehabib's Avatar
welcome to the forums!
Old Aug 30, 2009 | 07:44 AM
08700efi's Avatar
i dont know exactly how much you should have im thinkin over 80 for sure, call your local dealer tomorrow and find out how far did you drive it with no oil in it. did you keep driving it untill it just died? and did it have a workin oil light?
Old Aug 30, 2009 | 08:31 AM
My son was riding it and it slowly just died. Not sure how far he drove with "no oil". The hole in the oil box was at the front of the box in the middle. I think the oil return line comes in at the top of the box and the oil gradually ran out the hole. It was about 1.5" long by 3/4" wide hole. Not sure about working oil light. Can't say I've really noticed it before. It's all that LCD screen. Not like it's a red oil light.
Old Aug 30, 2009 | 08:35 AM
Also motor seems to turn over fine, sounds OK, no suspicious noise.
Old Aug 30, 2009 | 09:23 AM
08700efi's Avatar
well 50 psi is not enough cant give you exact numbers but should be close to 100
Old Aug 31, 2009 | 10:44 AM
BioWare's Avatar
Toxic Ryder
Welcome to the forums
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
