2002 Honda Recon having trouble to start when cold
Old Jan 14, 2011 | 09:33 AM
kolobok101's Avatar
Default 2002 Honda Recon having trouble to start when cold
Hi all, I need help with my used 2002 Honda Recon 250 es that I just bought, I did all the maintenance on it like motor oil change differential oil change spark plug and filter, also do I need to do valve adjustment and how often do I need to do it? But the main concern is that I’m having problem starting when its cold I pull the choke all the way up and takes me 3 to 4 times to crank it up then finally starts, what could be the problem? When worm starts fine.
Thanks
Old Jan 14, 2011 | 09:55 AM
Welcome to the forum. Try asking your question in the Honda section to get a better answer.
Old Jan 14, 2011 | 05:48 PM
wilson911's Avatar
Thanks
I have owned 7 carbeurated Honda machines over the years. IT doesn't sound like there's anything particularly wrong here. All the ones I have owned (and the three I still own) need the choke to start when they are cold.
Question is, if you run it until its warmed up then shut it off, will you need to use the choke then? It should start without choke when warm. If you need the choke when its warm, then there may be something wrong with the Carb. Usually cleaning it out, or just draining thw bowl and refilling will help.
But these engines are known to start rough in the cold but once its starts, it will run forever. Good luck.
Old Jan 16, 2011 | 06:10 PM
DODGE57HEMI's Avatar
Mopar Man!
Welcome!
Old Jan 17, 2011 | 03:06 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Some people size up the pilot jet for cold weather. Every atv/bike I've ever owned hated the cold. They seem to start easier in low humidity, too. Little starting fluid in the carb helps.
Old Jan 17, 2011 | 07:19 PM
BioWare's Avatar
Toxic Ryder
Welcome
Old Jan 18, 2011 | 07:33 PM
faruquehabib's Avatar
welcome!
Old Feb 10, 2011 | 02:36 PM
kolobok101's Avatar
thanks guys
Old Feb 12, 2011 | 09:58 AM
snow racer's Avatar
Welcome
Jun 10, 2015 12:45 AM
'86 TRX125
Jun 6, 2015 07:43 PM
ATV4ME
Jun 28, 2000 12:45 AM
j_quinn
Jan 30, 2000 12:40 AM
bgarre
Jan 23, 2000 10:17 PM
