2005 baja 110 4 wheeler
Old Aug 30, 2011 | 04:47 PM
jaysage's Avatar
Default 2005 baja 110 4 wheeler
selenoid makes a knock like sound when i push button but wont crank starter.checked all fuses,all wires,starter is new,battery is new.is there a way a way to bypass the selinoid.i just want to see if thats the problem
Old Aug 30, 2011 | 08:16 PM
Jaster94's Avatar
welcome to the forums. need to post in other forum. but while you're here....what's voltage on battery? have you jumped the battery? is it properly charged and holding voltage? jumped the solenoid with a screwdriver? engaged left handlebar brake handle to satisfy safety interlock? if applicable, neutral switch light on? a lot of variables to look at. but is does sound like the battery's voltage is down. charge it or jump it from your car....she'll go.
Old Aug 31, 2011 | 05:46 PM
jaysage's Avatar
Default battery
brand new battery,brand new starter,fully charged,could i hav a bad starter?or is this what the relay does when it goes bad?how would i check relay?tried jumping the relay with no luck.
Old Sep 2, 2011 | 02:07 PM
BioWare's Avatar
Toxic Ryder
Welcome
Old Sep 2, 2011 | 02:24 PM
Welcome to the forums. Try asking your questions in the Chinese quad section for better answers.
wrencher82
Sep 30, 2015 04:27 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
dakotah
Sep 26, 2015 04:25 PM
wrencher82
Sep 24, 2015 03:39 PM
