1996 polaris Xplorer overcharging
Old Dec 26, 2015 | 11:57 AM
Bigramcharger's Avatar
Default 1996 polaris Xplorer overcharging
Looking for HELP, I have a 1996 Xplorer that is over charging. I have replaced the voltage regulator. It will charger at 14.1vlt at idle went rpms are raised it will charger 18-19 vlts. I feel ike it may need a stator but would like to see if anyone else has had this problem.
Old Dec 26, 2015 | 01:23 PM
Check that you have the regulator hooked up correctly,but does sound like what a stator can do also. Do a general resistance check first. Yellow to yellow/red wires from the stator should show around .3 ohms resistance,yellow to yellow/brown .17 ohms. If readings exceed 20% of resistance values then yes it could be a stator problem.Stator Polaris Xplorer 400 1995 1996 1997 1998 1999 2000 2001 2002 | eBay
97exc
Sep 5, 2020 02:22 PM
Brandonz
1) Engine problems..
8
Dec 23, 2015 08:47 AM
shore
Dec 19, 2015 09:17 AM
itsbeal
Dec 6, 2015 07:41 PM
cornermike
Dec 4, 2015 12:58 AM
