2007 Kawasaki Bayou 250
Hello everyone how are you all doing? I'm a newbie here and having an electrical issue with my ATV. My name is Rodney and I live in the Western part of NC Mountains.
Please direct me to the correct forum to diagnose the alternator 3 yellow wire's that protrudes thru the rubber grommet next to the recoil starter.
My question is does it matter what 3 yellow wires connect to the regulator/rectifier??
What happen was previous seller dog played tug of war and yanked wiring harness out of the ATV.
Thank you for your insight.
Rodney
Rodney
I have a Electrical schematic from the manual. I have a new wiring harness coming soon. you can see in the picture that i will also need to put either a male or female connector on the 3 yellow wires to conect to new wiring harness.
My goal is to when wiring harness arrives connect wiring connectors to the CDI, Regulator/Rectifier, Coil, and Crankshaft sensor to see if i get a spark and or it fires up when i pull the recoil start.
Does anyone have a picture describing the CDI BOX pin connection chart to determine what wire goes where?
The CDI BOX is a : DENSO 21119-1457 / 070000-2600
Thank you
Thank you
arc burn
11
Jul 23, 2016 01:14 AM
