Help
Old Sep 15, 2016 | 05:16 PM
Budman63's Avatar
Default Help
I have a 2006 Polaris Sportsman 90 that bogs down after running about 10 minutes Has a new carburetor
I am at a loss
Old Sep 15, 2016 | 05:41 PM
Check that you have a good fuel supply running to the carb. If that is ok,then I'd check compression. Manual calls for 115 psi minimum but some can run a little while on 100psi or less,lose compression and die. Compression check would be the next thing I'd check.Electrical break downs can do the same thing. Here's a free manual that can help you. Hope it still works.2003 Polaris Scrambler 50-90 Sportsman 90 Predator 90 Service Manual[1] - Documents If it doesn't here's one for 5 bucks.2006 Polaris Sportsman 90 Service Manual PDF Download
Old Sep 16, 2016 | 06:58 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
OPT, does this model have a tank vent hose?
Old Sep 16, 2016 | 12:41 PM
They all have some sort of tank vent hose. This could be a problems area also if the vent line is kinked. Could restrict fuel flow until it got another good gulp of air.
cornermike
Aug 24, 2016 10:35 AM
papa hogg scoot
Aug 19, 2016 06:45 AM
MikeMc48
Aug 17, 2016 03:49 PM
Sparkynutz
Jul 12, 2016 10:54 PM
Brandon whitford
Jun 28, 2016 07:19 PM
