Chinese atv 110cc
Old Sep 16, 2018 | 08:23 PM
AbdulAziz Afridi's Avatar
Default Chinese atv 110cc
Hello guys
hope someone could help me solve this.I have already lost an atv engine cause of this problem as i messed up the valve setting, the second atv i have has the same problem.Both these atv were standing for a long time.The problem is that the fly wheel is very hard to turn when the piston reaches the compression point even by hand or wrench.It turns fine when i take out the spark plug as no compression can be made at that point but after putting in the spark plug the flywheel takes a little force to turn over which the electric motor or the fully charged battery cannot provide hence the solenoid only clicks.Does it has to do something with the valves?are they too tight or loose?Do i spray wd 40 into the piston cylinder?I have searched this problem on the intenet so many time,many people have but i wasnt able to find the answer.Thank You.
jackhm
1) Engine problems..
Dec 1, 2011 12:09 AM
DHirschy
15
Jun 20, 2011 05:48 PM
keltikayla
56
Mar 15, 2011 06:08 AM
blueman1388
Mar 24, 2007 10:55 AM
darknight23
Oct 10, 2006 06:02 PM
