Holeshot module test
Old May 28, 2003 | 02:51 AM
rivermud's Avatar
Default Holeshot module test
MnTurboPaws, Looks like trailburner has you covered. The phone # is (714) 299-3865. Its normal that they dont answer, but leave a message and they will call you back. Tip>>> When your installing the module with a switch, and you cut the pink wire add a piece of wire to it. Otherwise the pink wire will be to short to let you secure the switch in a good spot out of the way of the seat. I just used an inline conector with shrink tube over it. Then retaped the harness. Looks original (except for the microswitch).
Old May 28, 2003 | 08:41 AM
MnTurboPaws's Avatar
...Thanks, I'l get right on the phone...I miss the power since I put on the bigger ITP tires
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
