do my valves need retiming (mojave)
Old Jun 29, 2003 | 12:55 PM
sickmojave's Avatar
Default do my valves need retiming (mojave)
start with a compression test. dude if it pulled dust in the carb it only takes a little to do alot.
Old Jun 29, 2003 | 01:21 PM
boob's Avatar
to get a good idea of if the compression is good or not is to put your finger over the spark plug hole and crank over the engine, if your finger blows away then compression is good enough, this might not sound to precise but it gives you an idea if its good or bad, chances of the valves closing on you like i said before is a really good one, im only saying this because it has happened to me lots before, also make sure that your carb is on the manifold completly if in doubt undo the clamp and press in the carb also i would recommend using a regular hose clamp instead of the stock clamp, these seem to give better coverage
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
