speedo and 4wd not working
Old 06-27-2003, 02:36 PM
atcfan's Avatar
Default speedo and 4wd not working
my friend has a 03 650 praire and the other day he drove it and noticed that his speedo was not going over 0 mph and also his 4wd was not working? any ideas on what is wrong?
Old 06-27-2003, 02:44 PM
nyroc's Avatar
speed sensor got crushed/damaged/unplugged. It's by the pivot for the foot brake. Take a look.
Old 06-27-2003, 03:20 PM
atcfan's Avatar
thanks i will give him a call tonight.
Old 06-27-2003, 03:26 PM
kawip650's Avatar
i had the exact same problem with my speedo and 4wd, but my problem turned out to be something in the CDI was fried. The first thing the dealer did was change the speed sensor but it didn't fix the problem, then they switched out the CDI and it took care of the problem.
Nyroc, great directions on installing the black spring. i made a spring compressor just like yours and it work great, it took about 30 minutes from start to finish. with the black spring i can wheelie with ease, high or low range. with a little pull on the handle bars i can stand it straight up while doing about 15mph, maybe even faster. thanks!
Old 06-27-2003, 07:46 PM
Scooter650's Avatar
When my speed sensor failed, the speedo worked fine, just the 4WD didn't work. Might be the speed sensor, pretty cheap fix to try, $40 from Ron Ayers.
hugemoth
07-20-2020 03:28 AM
rcappie4
07-18-2015 07:51 AM
timster911
07-13-2015 01:57 PM
J-Mack
Polaris Side by Sides
07-04-2015 04:19 PM
bikedad3
07-02-2015 02:15 AM
Quick Reply: speedo and 4wd not working
