YEEEE HAAAA I pick up my 700 Prairie in the morning!First ride reports!
#31
Just checked buykawasaki myself, and unless I'm way out to lunch, part #'s are the same (and parts look the same) for the 700 and the '03 650. Clutches look a bit different from '02 to'03 on the 650, but the later '03 650 is the same clutch as the 700. Belt is the same for all, unfortunately, so is the CDI. I could be wrong, but thats how it looked to me.
#32
Yeah, the belts are the same for the P700 and the V700, guess I got my parts mixed up. Good correction there muddin650.
I went and checked the CDI part numbers again. I found it interesting that the CDI boxes are different on the 02 P650 than the 03 P650. You are right though, the 03 P650 and the P700 have the same CDI boxes. Also, with the larger belt on the P700 it should be faster on top end than a P650.
Here is a break down of what I found.
2002 P650
Belt # is 59011-1080
CDI # is 21119-1598
2003 P650
CDI # is 21119-0004
2003 P700
Belt # is 59011-0003
CDI # is 21119-0004
2004 V700
CDI # is 21119-1629
I also notice that a change in drive and driven converters was done from the early 03 P650 and the late 03 P650.
I never bothered to try and find out but what is the difference in the 2002 KVF650A1 and the 2002 KVF650B1? What is the difference in the "A1" and the "B1"?
2002 P650
CDI # is 21119-1598
2003 P650
CDI # is 21119-0004
2003 P700
CDI # is 21119-0004
2004 V700
CDI # is 21119-1629
#34
#35
#38
The difference between the A1 and the B1 is the A1 is the red or green models and the B1 is the camo model. That's the only difference between the two.
2002 KVF650-A1 red or green color
2002 KVF650-B1 camo color
2003 KVF650-A2 red or green color
2003 KVF650-B2 camo color
2004 KVF700-A1 red or green color
2004 KVF700-B1 camo color
