prairie 700 can't decide 2wd or 4wd
Well 26yearoldbeginner i pulled off the clutch cover and blew out all the dust and in the process i flipped the belt wear indicator switch. i flipped it back but the belt indicator light keep flashing. i tried disconecting the battery but that didn't work. does anyone know how to reset the belt wear indicator.
i might end up having to take it to the dealer but i called him and he said that they have blown all the dust out of the clutch housing and that solved the problem and to give it a try if i wanted.
My friend had the same problem--there is a little black box on top of the clutch cover--disconect it--follow that wire towards front of vehicle--2 other connections are there in that loom--disconnect then & reconnect them in oppisite order--turn on key 4 about 10 seconds --turn off key--reconnect in original connectors--should be good 2 go
