new cdi for v-force scary thought
Old Nov 18, 2003 | 11:25 AM
MnFriesen's Avatar
Default new cdi for v-force scary thought
ok if the pistons mentioned were used 1. what type of gas would you need to run 2. would it void the warrenty?
Old Nov 18, 2003 | 11:41 AM
RocketJoe's Avatar
Originally posted by: HELIX
I have an offset timing key in mine giving it 3 more degrees.
HELIX,
Can you give advice on how you did this?
RJ
Old Nov 18, 2003 | 12:42 PM
SHOTGUN's Avatar
The Vforce igniter keeps 28 degrees evn at high speed.It does not fall off at 6500 rpm like the prairie.I have an offset timing key in mine giving it 3 more degrees,along with high comp pistons,still no detonation.
I agree with Helix, if the V is already at 28 degrees and 32 degrees is said to be the very best for that motor, why wait for a CDI, when a $5.00 key will do the same thing. I'm sure the new CDI will raise the limitor, but is anyone close to the old limitor.
Now the 650 is a different story, we need more advanced timing than a key will give, and I been on the limitor in low gear.
Old Nov 18, 2003 | 01:01 PM
garyc660R's Avatar
Originally posted by: fullthrottlevforce700
so your power falls off with new cdi only thing got chance in drag race a fully done up banshee
ROFLMAO!
Old Nov 18, 2003 | 02:10 PM
  #15
RocketJoe's Avatar
SHOTGUN,
Do you have a supplier of the offset timing key you used?
RJ
Old Nov 18, 2003 | 02:31 PM
  #16
SHOTGUN's Avatar
Mickey Dunlap or Mike Penland sell the 6 degree keys, ask Helix on the three degree, he probably sells them.
Old Nov 18, 2003 | 05:01 PM
  #17
DesertSportsman's Avatar
Kawy or Helix
How come Wiseco list's the 650 2mm over piston's as 665 in displacement? If I recall the V is 697? I just want to make sure I order the correct ones. Wiseco part# 4782M08200. Thanks for your help. Also what's involved to install the offset key?
Ken
Old Nov 18, 2003 | 05:27 PM
  #18
reds650's Avatar
the stroke on the 650 is 63mm - 82mm bore * 63mm stroke * 2 =665
the stroke on the 700 is 66mm - 82mm bore * 66mm stroke* 2=697
hope this helps
Old Nov 18, 2003 | 05:29 PM
  #19
Crankdog's Avatar
Since someone is talking about pistons, does anybody know if a 11:1 compression is available for the 650 in a standard bore. I was also wondering if cams are recommended with this setup, and what kind of performance gains would be expected by the pistons alone, and with the addition of aftermarket cams with the pistons?
Thanks,
Crankdog
Old Nov 18, 2003 | 05:34 PM
  #20
reds650's Avatar
IF you know how to deg a cam do it to the stock ones[p650-p700] to v-force specs
big diffrence[img]i/expressions/face-icon-small-happy.gif[/img]
