650 rear Spring Adjustment
Old Dec 16, 2003 | 07:21 PM
kodiac1's Avatar
Default 650 rear Spring Adjustment
I was thinking of upping the tension on my rear spring.When I put my cargo box on the back it sags more than I like.Has anyone done this? and if so how far did you go? Any tips would be appreciated.Thanks
02 650 camo
Old Dec 16, 2003 | 08:03 PM
Adirondack's Avatar
I adjusted mine to w/in a 3/8 inch of the top of the threads. It seems good to me for fast trail riding w/ a fully loaded cargo box. Trial and error will help you to find the best place for you. I found it easiest to adjust by removing the shock from the quad. Good luck w/ it!
Old Dec 16, 2003 | 09:46 PM
LuvDaMud's Avatar
I adjusted mine to the max tension. It's not easy but I used a hardened
steel rod and a hammer to turn the nut. The key supplied with the bike
only works if you take the shock off. I blew my first shock out by jumping
with a cargo box on the back + a 2 gal jug of gas in a bakrack. Don't want
to blow this one so I took the gas rack off.
___________________________
2003, p650 red
Holeshot Module
Dalton clutch springs
ITP cast alum rims
26in Bear Claws
Kimpex snow trax( for deep snow)
full equiped
Old Dec 19, 2003 | 12:24 AM
skun's Avatar
Could you please tell me what a epi black spring does and where it goes? i just bought a 650 prairie it has 4000 kms on it and i was wondering if anyone could give me some pointers on it like what to look for for problems etc any info you could give me would be greatly appreciated
Old Dec 19, 2003 | 05:32 AM
DaveC's Avatar
Skun, you need to start a new thread. I'm sure someone will help you out.
I don't know all the technicalities of the black spring, but I do know that it helps your belt ingage sooner which saves your belt in the long run. My 2003 650 doesn't seem to need one as it will creep on it's own if I raise the idle up- belt engageing early enough for me.
Old Dec 19, 2003 | 09:11 AM
schl48's Avatar
the black spring helps it down shift faster. tt racing i had a problem with slowing down for the corners and when i pushed the throttle down to pick up speed it didn;t down shift witch felt like it was in 3rd gear instead of 1st or 2nd. the black sring completely cured that promblem.sometimes the stock spring worked good but occationlly it didn't.( secondary spring), hope this help!
ghost civic
Jan 15, 2020 07:43 AM
rcappie4
Jul 10, 2015 04:54 PM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
