Anyone ever tried a Dalton Industries Clutch kit???
I have the epi black secondary spring, and the dalton plain with white stripe primary....... dalton secondary spring is the same thing as epi's. Dalton primary spring made the mid range a hole lot more peppy, holds the gear at higher rpms, and the black secondary spring is more less for belt life. (Tight belt = long belt life) So to sum up you question, awsome kit, imo and it's easy to install yourself.[img]i/expressions/face-icon-small-wink.gif[/img]
i have just installed the dalton kit with the blue spring and weights, i also installed the dalton pulley.
i was not able to test and compare between other setups but i have seen an improvment in my racing over other atvs,
i would also like to hear if anyone has any coments between the epi pink and the dalton blue????????????
hope to decide soon on air box mods or snorkels, maybe after that i will have more positve results.
Elkaholic
Sep 6, 2015 02:44 PM
