Cold Starting V-Force
Old Jan 18, 2004 | 10:33 PM
MikeCer's Avatar
Default Cold Starting V-Force
Its not been too cold here, but what I was told to do was go full choke for about
10-30 sec, and then try starting.. it should start right up, let it run for 2-3 min at full
or 3/4 choke and you should be good to go..
Old Jan 18, 2004 | 11:15 PM
encieno's Avatar
oops, i started mine up the other day and finally remembered to leave the key on for a few seconds prior, let it go about 10 seconds than amazingly it started on not even the second crank, haha.
Old Jan 18, 2004 | 11:27 PM
tyzorg's Avatar
im serious just use a squirt of starting fluid only around 3 bucks for a can and it starts it like a charm.. if i didnt have that i would have to crank for about 2 mins to have it start and stall and try all over again
Old Jan 19, 2004 | 11:16 PM
MentalState's Avatar
Starting fluid is good but horrible on your cylinder wall.....
Old Jan 19, 2004 | 11:24 PM
  #15
tyzorg's Avatar
ah well its good to breath any way.. wakes u up know what im saying? LOL
Old Jan 20, 2004 | 05:44 AM
  #16
Brushog's Avatar
Most Kawies are hard to start cold. Main thing is carb & valve ADJ. Un less worn Kaw. If newer,find a Mech. Or read. Ha. Maintain it & it will run for a long time. Brushog
MikeyBoyesq
Nov 27, 2020 02:44 PM
Big600twin
Jun 10, 2015 03:01 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
86atc250r
Jul 28, 2000 02:40 AM
