Beating a Dead Horse - Spring Replacement for the V
Old Jan 16, 2004 | 05:32 PM
Jaybe's Avatar
Default Beating a Dead Horse - Spring Replacement for the V
I know this issue has been covered many times but I need some help. I am installing the Dalton Clutch Kit. Are there any alternatives to having a Clutch Puller? Also, does elevation matter when it comes to the actual weight of the fly Weights? Thanks!
Old Jan 16, 2004 | 08:02 PM
MentalState's Avatar
I am no expert but elevation might play a part in it...As far as a puller goes I dont think you need it to put in kit...
Old Jan 16, 2004 | 08:07 PM
Jaybe's Avatar
Thanks, I am kinda in a bind. I have removed the plastic clutch cover, removed the center bolt from the motor clutch but I do not know how to remove the drive clutch. The instructions say to use a "puller". I have called all the local Kawie shops and they do not have one to sell. I can order one from Dalton for $37.00 plus shipping but that is my last resort. Any Help would be appreciated!
Old Jan 16, 2004 | 08:18 PM
DesertSportsman's Avatar
YOu can remove the belt and then you can change the weights. Altitude not a factor with the V as far as weights.
Old Jan 16, 2004 | 08:31 PM
Vforcer's Avatar
The rear pully comes off without a puller ..... that will let you remove the belt. With the belt off, you can change the weights and spring without removing the front pully.
Old Jan 16, 2004 | 08:35 PM
Jaybe's Avatar
Thank you guys! I appreciate it!![img]i/expressions/face-icon-small-smile.gif[/img]
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Aitch
Jul 21, 2015 09:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
