p 650 top spped
Old Feb 1, 2004 | 04:37 PM
hammerman's Avatar
Default p 650 top spped
Mine will only go 61 or 62 mph on a long straight stretch. Everything stock.
Old Feb 1, 2004 | 09:18 PM
HavinSomeFun's Avatar
So what determines or would effect the top speed? Lets say the belt deflection was in-spec. what else could slow down a machine. Carb settings? Jets? I have even wondered about the exhaust flow. What is everyone elses thought on this. And has anyone increased top speed by doing something.
Old Feb 2, 2004 | 12:58 AM
Customfabandweld's Avatar
Mines not really broke in yet(33 miles), so I haven't really pinned it, yet. I have had it up to 50 MPH a couple of times, but acceleration REALLY drops off after 45 MPH. Is this normal?
Old Feb 2, 2004 | 01:21 AM
92LT's Avatar
I have an '02 and I've never seen 60 mph on it. I've even had it back at the dealer I bought it from and the mechanic couldn't figure out why mine was slower than the others. Maybe because mine is one of the very first ones released (low vin #). BTW, I've never been able to pull a wheelie either! I have a feeling my belt tension is off - I do plan on checking it soon.
Old Feb 2, 2004 | 03:58 AM
  #15
cartman308's Avatar
the dead spot in the midrange is normal with a stock 650 clutch spring. A p700 spring on any other aftermarket spring will wake up the beast in the middle. With the outlaws the fastest i cared to go was 55......has ALOT of front end wandering then!!! With the ATRs i've been as fast as 62mph and seemed to have PLENTY left to go!! Never really seen top end on mine!!
Old Feb 2, 2004 | 09:56 AM
  #16
skun's Avatar
yea CARTMAN 308 a little question,witch clutch did you put the p700 spring in was it the primary? And how much difference did it make? thanks Skun
Old Feb 2, 2004 | 11:03 AM
  #17
newbeatle's Avatar
you use the 700 primary spring...
Old Feb 2, 2004 | 02:13 PM
  #18
SHOTGUN's Avatar
Everyone with larger tires, needs to figure that into their speed.
For example, my stock tires, which my speedo is cal. to travel 78.5 inches every rev.
My pulling tires, travels 97.34 inches each rev. so I would need to add 8 % to the speed.
70 Mph = 75.6
If I did it right. GPS is the best way.
beergut
38
Sep 23, 2022 11:16 PM
mrcountry
Aug 21, 2009 09:13 PM
MnTurboPaws
Oct 11, 2008 10:51 PM
quadfreek2000
May 29, 2008 08:54 PM
michigan-man
Oct 24, 2007 10:55 AM
