Prairie Shock Stiffening
Old Feb 28, 2004 | 01:33 AM
RedGoblin's Avatar
Default Prairie Shock Stiffening
I'm going to be riding a 650 Prairie for it's sportier abilities this Sunday and I was wondering if there was a simple way to jerry-rig some kind of stiffening on the front shocks to eliminate the front end roll in hard corners. Any ideas that may work are welcome. Thanks!
Old Feb 29, 2004 | 01:27 AM
Customfabandweld's Avatar
I would also like to hear something on that subject. Is there a preload adjust?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 29, 2004 | 11:39 AM
MEEKROL's Avatar
I had a problem scrubing on the front. I took the two lower strut bolts loose (the bottom bolt is inset 1/8" and must be removed to do this) droped the spindel 3/4". put the top bolt back in. Find a drill the same size as the bottom hole run the drill in to make the hole round agan. put top bolt back in reasemble all . 3/4" font lift.
Old Mar 5, 2004 | 09:09 PM
NDawg's Avatar
I know the rear shock can be adjusted pretty easily, but is there a way to pre-adjust the front shocks, like how the rear is with just turning the shock?
Old Mar 5, 2004 | 09:54 PM
DirtVH's Avatar
I wondered about making some kind of spacer or even a threaded sleeve witha big washer and nut to adjust it to put more tension on the springs. Has anyone tried something like this.
Old Mar 5, 2004 | 11:50 PM
mudmagnet's Avatar
Just buy the ELKA springs. They will ship them to you in three days and they only cost $225. They are a cinch to put in, plus you can set them up any way you want them.
Old Mar 6, 2004 | 03:57 AM
What's the difference between Elkas, and Progressives?
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
PrairieDog126
Sep 12, 2015 05:23 PM
