new black spring
yesterday I went ahead and started on putting in the new secondary black spring. I used atvpower to guide me through the job. i just wanted to add a couple toughts if anybody else is going to tackle this job. Use a impact gun to remove the 27mm nutt of the secondary spring. I found it hard to wrench down the nyroc tool bc the end cap would slide off under the pressure so i cut a piece of pvc pipe that fit on the inside to make the walls extra strong. This got it done. atvpower
I just did the black spring mod last week as well. I used neither of the tools recommended. I used 2 pistons from an old motor laying around and bolted the conrods together making a good handle and pushed down on the spring while my buddy put the circlip back on. Worked great. A little backwoods ingenuity i guess, but it worked!
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
