Cracked P650 battery tray....anyone else??
While servicing the wifes 2002 Camo 650 I noticed that the area where the battery hold down bracket bolts to the lower two bolt holes in the plastic tray where cracked with only a 1/4" of plastic left holding the tray. The battery hold down bracket doesn't seem to hold the battery tightly to the tray, it has a 1/2" of room to allow the battery to flop around. This is the original battery, if I replaced the plastic tray I think I'm still going to have trouble with the battery bouncing around. Has anyone else encountered this?
Thanks
Idahopraire
Thanks
Idahopraire
been there.... Just leave it and put bigger washes on it. I also started by putting a wire clamp around the plastic cover but after a while I left it off. Batteries move around abit anyways if you want too buy some door foam tape, the small stuff and stick it in the middle of the plastic cover. I was going to fab a metal strap over the plastic. I wouldn'tjust replace the plastic tray... it will do it again.
cody500ho
14
Aug 14, 2015 05:03 PM
