dyna cdi makes motor kickback when starting.
Old Apr 28, 2004 | 09:19 PM
  #61
Travellers's Avatar
Default dyna cdi makes motor kickback when starting.
I experienced kickback today several times, I always use the key to shut machine down. I experienced it when starting machine in gear using the brake lever. I started putting in neutral and started it several times with no kickback. Coincendence probably, may take new CDI out until someone sorts out. I know it is not battery or loose cables, will try a lower idle tomorrow.
Old Apr 28, 2004 | 09:26 PM
  #62
zelphia's Avatar
I've been following this thread with keen interest. I have a CDI ordered but it won't ship till June. I'd like to suggest that one of you gurus check the timing with a timing light. My guess is that it is being advanced beyond 5 deg by the CDI during crank and at idle. That would explain the fast idle that all have experienced...and also the kickback problem.
  #63
Prairie700's Avatar
Humm > So far, no kickbacks on my 04' P700. Probably 30 starts since Dyna CDI install.
I do however keep the battery on trickle charge when I'm not riding - Just an old habit I developed years ago. Seems to help wet cells last longer...
Wish I could remember for sure, but I'm (almost) positive I had to reduce idle after the cdi. Problem is, I also adjusted air/fuel screws due to cdi.
Old Apr 28, 2004 | 09:34 PM
  #64
deerchooper's Avatar
NYROC
my idle was high with the cdi. i turned it down the same day.
i really didnt notice any kick back though. i will see this weekend.
__________________
02 650p
nyroc muffler
super snorkle
155f/158r jets
needles shimmed .033
3 1/2 turns on the pilots
dynatek cdi
epi black
700p drive spring
warn 2000
plow
Old Apr 28, 2004 | 09:55 PM
  #65
SHOTGUN's Avatar
Scott, why wouldn't the stock CDI get kickback, if in fact the voltage was the problem?
Does your CDI require more volts than the stock one?
Old Apr 28, 2004 | 10:02 PM
  #66
NovaKaw650's Avatar
Originally posted by: nyroc
Nova, the standard map and reverse map are identical from 0 to 1500RPM, so whether you have a holeshot of not, you have 5 degrees timing. Therefore having a holeshot wont change the idle speed (at 1100rpm). If your idle was set to 2500, then the reverse map would slow the idle down for 3 seconds and have no effect after that (basically holeshots do not affect the idle).
Nope. My machine at a 1200 RPM idle will immediately jump to 1350-1400RPM's when I turn on the module. (I have a switch on the bars). I've seen 2 others do the same thing; theirs had no tach, but you could hear the idle speed increase with the module. This was with either a Freedom or reds650 module, both had the same effect.
One more point - I'm running a 6 degree key which puts me one degree above the Dyna CDI at an idle or at maximum advance; no hint of a kickback.
Old Apr 28, 2004 | 10:47 PM
  #67
Customfabandweld's Avatar
No Problems with mine, at all. However, I am very curious that almost everyone is experiencing easier starting(when they aren't kicking back), and it idles higher with the Dyna. There is 1 and only 1 explanation for this, THE TIMING IS DIFFERENT FROM THE STOCK TIMING, AT IDLE. Scott keeps saying that their timing is the same as stock, at idle. I have very little experience in electronics, but common sense says that there HAS to be a difference at idle speeds. Please correct me, if I'm not seeing this right.
Old Apr 29, 2004 | 12:05 AM
  #68
kawakasi's Avatar
CF&W
Excellent point!!!
Old Apr 29, 2004 | 12:15 AM
  #69
KISSSOFDEATH's Avatar
My idle increased approx 100-150 with the new CDI, just as it did with the test CDI that nyroc got from Sgtrock. I started the P650 10 times, tonight with and without using the kill switch and got no kickback this time. Like I told Scott on the phone, I will ride it next weekend and see how it does. If the performance is exceptional I will accept the kickback, if the performance is the same as stock or just marginal then I will send it back for testing.
Old Apr 29, 2004 | 12:38 AM
  #70
You WILL have a performance increase! I can wheelie again in high gear, which I couldn't do after the cam redegree.[img]i/expressions/face-icon-small-happy.gif[/img]
