my V radiator leaks, can i........
yeah it's the rad, been lucky to get this far out of it, sure has taken some hits from all the crashing i did in the beginning hehe. it no longer drips, it pours. gonna take it out and see if i can get it fixed 'till i save my pennies for an IMS. the cheapest i can get a new stocker is $450, i'll get the IMS for $400! always go with the upgrade! just sux that it breaks right in the beginning of prime ridin' weather!
only seat of the pants......i bought the mid to high and noticed a worthy gain all over the powerband, wheelies everywhere, can let off if needed on big banks-crack back on and actually have power, doesn't fall on it's face after midrange anymore-pulls to the top. very loud, my quad is the loudest around, i ALMOST feel bad about it's noise but it sounds sooo good, cross between a harley and a small block chevy, i'm sleeping fine at night.........i got radared on the ice, stock pipe, with studs, 22" klaws on itp t9s at 70mph. then on tar with pipe, 22" realtors on stock wheels at 73mph. i'm not sure how of a difference the heavier realtors and temperature makes. that day a 440ex went 71, 450r went 72 and 83 for a 686 rappy, figured i'd throw that info in for kicks. i rode a stock v back to back with mine and feel that mine has a substantial gain in power. i still want a yfz.
FYI...NYROC... I had my radiator professionaly repaired last year, ( just before my rebuild )... see the connection... the aluminum & plastic radiator did not take the repair well, & after mudding, I just assumed that it was OK... next thing my heads are warped, & I'm talking to Mickey Dunlop... I did try to install a Dodge Neon radiator in mine, & that may have worked, but the damage to my engine was already done... don't put the stop leak in, it will cause more problems, than it fixes, also if you decide to have the radiator repaired by a shop, keep a very close eye on it... the 1st mud & following radiator wash out, & mine was leaking again...
