clutch tuning questions
Old May 6, 2004 | 03:14 AM
Enigma's Avatar
Default clutch tuning questions
What does heavier clutch weights do? I know it brings a springs stall back down. Why would you not just buy a spring without stall? Or zero stall with a high shiftout?
What does the dalton overdrive cover do? I know its lighter, but what does that make it do?
Are these mods beneficial on a stock bike or do you need pipe/airbox mods & jetting to realize a benefit?
Old May 6, 2004 | 11:18 AM
SHOTGUN's Avatar
Weights supply the leverage to make your v shift gears. The heavier the weights the faster it will shift, if you can hold the same RPM's. The Dalton clutch plate is lighter, so you can add heavier weights to shift faster, also it is made to give more top speed by letting your clutches close more.
Dale @ Dalton has a V that he races, I would suggest talking to him about the plate and weights for a stock V.
ghost civic
Jan 15, 2020 07:43 AM
Ashley S
Aug 6, 2015 12:56 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
