prairie 650 Transmission problem
what I called the shaft spline, is where the shift linkage attaches to the shaft on the transmission. Kawi PN#13236-1343 If you look it up in Kawi parts fiche (LEVER-COMP,CHANGE LEVER) It has a 10mm flanged bolt, keep this tight, I don't know the torque spec, but tight is good.Parts Fiche
