Exaust leaks with Yoshi duals
I love the look and sound of my Yoshi system but I have leaks at crossover tube and at the joint where right tailpipe meets the front header. I know I could probably cure the leak at the header joint if I could move the tailpipe up further on the front header, but I can't because the crossover tube prevents it from moving up anymore. I have just applied some exaust leak compound to the joints and will see if that works. I am considering cutting off the crossover section between the 2 tailpipes and welding the holes over...Anyone else have the Yoshi duals with this problem?
exmotocrosser
Sep 13, 2019 06:12 AM
Sep 30, 2015 01:37 AM
