drain plugs
Old May 17, 2004 | 11:14 PM
Crawdaddy's Avatar
Default drain plugs
I know this might sound stupid but this is my first quad a 02 P650. Where is the back spark plug do I need to remove any plastic? Also I found the drain plug but where is the fill plug on the front and rear diff's and is there a fuel fliter that might need to be changed.
Old May 19, 2004 | 04:58 AM
AlaskaBayouGuy's Avatar
Default drain plugs
Do a search for posts on this topic -- ive seen this question here many times before..
Old May 19, 2004 | 09:49 AM
newbeatle's Avatar
Default drain plugs
CRAW... I highly recommend a service manual... this is a fairly complex machine, & there are a lot of mainenance & service items you can actually do better than your dealer can ( knowing the way you ride, & your time frame )... the torque specs are in there, & it is not uncommon, to twist off CVT belt cover bolts, etc. with out the torque specs...
Shainasmash
May 8, 2017 06:38 PM
SDR-II
Sep 29, 2015 01:06 AM
Polaris5
Aug 29, 2015 09:11 PM
JohnnySplat
Aug 6, 2015 12:07 PM
momma's bike
Aug 6, 2015 09:49 AM
