Jet needle adjustment???
Old May 27, 2004 | 05:34 PM
WileyCoyote's Avatar
Default Jet needle adjustment???
I'm going to put in some leaner main jets for my local altitude (6,000-8,000 feet). It currently runs fine, but the plugs are looking a little nasty (all black), and it loads up and backfires when coasting down from high speed. I'm not talking a little popping, but a hugh KABOOM!.
Will it be necessary to adjust the jet needle? Most people talk about shimming their needles (to make a richer condition), but how do you go the other way? Or is it even necessary?
Old May 27, 2004 | 05:59 PM
OleManMoses's Avatar
I wonder if your too rich at full throttle (mains) and too lean at idle (pilot) I still think my pilot jet is lean because of backfiring and backing off when letting off throttle--I have adjusted my fuel screw out 3 1/2 turns to try and reduce backfiring but out that far seems to hurt acceleration. I have screw somewhere around 2 1/2 turns (cant adjust on a 360 while running because screw is impossible to get to) and looking forward to increasing pilot jet size
Old May 27, 2004 | 06:38 PM
bbertram's Avatar
WileyCoyote......its only natural to go KABOOM with a name like that. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 27, 2004 | 06:50 PM
Initially, I thought a lean condition could exist also. But the pop-pop-pop you get when lean isn't the same as the cannon fire I'm getting out the tail pipe. According to the Prairie service manual, backfiring can occur because of a rich condition, and the appearance of the plugs would seem to corroborate that. Furthermore, I almost never need to use the choke, so apparently the mixture is rich enough as is, and would only get richer as the engine warms up.
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 24, 2015 03:39 PM
