Bypass neutral/start switch on Bayou?
Old 04-29-2018, 01:53 PM
Kymco 450i's Avatar
Originally Posted by merryman
I repeat "Why would anyone want to do this? More strain on the starter motor, and liable to lurch forward as soon as it fires up."
Unless you are terminally stupid, Kimcos argument only applies if you are in 1st or reverse, because Kawasaki clutches won't stand setting off from standstill in higher gears, for long. Is it that much trouble to change from reverse or first into neutral?
my 300was a cvt tranny so there was no issue, however, my wifes yamaha had that feature, but it would only start with the brake engaged. I do not see any safety issues there.
Old 07-20-2019, 07:06 PM
Steven Zantjer's Avatar
Default Where is it
I was just wondering where is that relay located? I would like to do the same thing.
Originally Posted by Z28ROC
Thanks guys, I figured it out, just after I made the post. It has a 4 pin starter relay. I just had to connect 2 of the wires together. Everything works great!
hueby
1) Engine problems..
08-29-2015 08:34 AM
hueby
08-28-2015 07:26 PM
frostphase
08-19-2015 07:11 PM
Atvnewb88
08-19-2015 02:22 AM
Atvnewb88
08-13-2015 06:48 AM
Quick Reply: Bypass neutral/start switch on Bayou?
