Belt questions...
I have a couple of quick questions:
At around 52 hours, my belt indicator light started blinking, and she wouldn't go over 5 mph. It is an early '03 650, but I still figured it was the belt switch since the belt had started to chirp a bit on take-off.
When I opened it, the switch had not been tripped. So my 1st question is: has anyone else had their light start blinking this early? I thought it was supposed to blink every 100 hours or so.
While I was in there, I installed the EPI black spring and a 700 belt. After removing a shim, and installing the new spring and belt, the deflection is now .8125". The belt does whine a little at idle, but once you start moving it feels perfect.
Do you think this is too tight?
Thanks,
-Matt
Thanks,
-Matt
It isn't too tight. Mine has been like that for 1000 miles. They last longer that way, just dont leave it idling in gear.
belt light reset
belt light reset
Jeff Roper
Feb 1, 2022 11:48 AM
