Sand drags for the Prairie
Old Jul 23, 2004 | 10:37 AM
DirtyWhiteBoy's Avatar
Default Sand drags for the Prairie
Gotcha. My friend must have swapped his (or?). I thought it was odd that Kawi would do that. Except the new Brute does have 4/110 studs. So, it didn't seem too weird after that.
Old Jul 23, 2004 | 01:32 PM
brads's Avatar
Originally posted by: newbeatle
I assume you a trying to get the waste gate set up for the rpm range on the turbo ???
I don't think the wastegate is what is going to need to be sized for RPM, as much as the turbine and compressor wheels to make sure its something that will reach full boost quickly enough, and flow as much air as possible. Sounds like a fun project.
The Dyna has a 9200 rpm rev limit. You might also want to pay attention to how much advance it has, it may be too much if you are running a turbo.
Brad
Old Jul 23, 2004 | 10:11 PM
vtwinriot's Avatar
If he were running too much timing for a turbo could he just install a 4 degree offset key backwards thus acheiving 4 deg less? He could then keep the Dyna.
Just a thought.
Chris
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
PrairieDog126
Sep 12, 2015 05:23 PM
