long ride..................problems
Old Jul 30, 2004 | 11:34 PM
tmaxx's Avatar
Default long ride..................problems
I was riding my lakota yesterday for about 6 hours straight, besides stopping for gas and a 15 minute break. I was riding on muddy trails and dirt roads most of the time--full thorottle on roads. When i was done i let it sit about an hour......washed it off, and noticed that it was running a little sluggish. When i went to start it up today, it started then stalled(never has before). after 3 or 4 tries it started, but wont idle smoothly and cuts out alot. Anyone know whats wrong??
Old Jul 31, 2004 | 12:03 AM
tmaxx's Avatar
i forgot to add that my engine has been making a clicking sound for quite awile now. it gets real loud for a second or so if i hit the gas at low speed. i thought it might be the valves(not sure). if it is the valves, what will happen if i dont adjust them?
Old Jul 31, 2004 | 03:22 AM
Crawdaddy's Avatar
If the valve adjustments are off that much I would not recommend starting it at all. You might bend a valve, crack a piston or tear a lot of other stuff up.
Old Jul 31, 2004 | 03:51 AM
rescuediver's Avatar
While reading your initial post, I was thinking water got into something and that's why it's sluggish. I know when I wash my quads, I run them and then spray WD-40 on all the electrical areas among other things. BUt when you posted your second post, I thought of your valves and low oil level to begin with.
Old Jul 31, 2004 | 03:05 PM
tmaxx's Avatar
it sounds like the clicking sound is coming from someplace around where the clutch cover is. it dosnt make much noise when the engine is idling or once i start moving, but as soon as i give it some gas i notice a few loud clicks(then it gets quieter) ??????&?
Old Jul 31, 2004 | 10:45 PM
NovaKaw650's Avatar
Hopefully not the crank after all that extended wot operation. Maybe you're lucky and it's just the cam chain.
Old Jul 31, 2004 | 10:48 PM
Kawibayou185's Avatar
I agree with novakaw650,sounds like the cam chain.
Old Jul 31, 2004 | 11:02 PM
tmaxx's Avatar
is it normal for it to click or does it need adjusting...........replacing?
Old Aug 1, 2004 | 09:44 PM
As they get wore out, they're known to click like that, eventually you will need to replace it but not right now I wouldnt think.
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
