2wd 4wd flashing
Old Aug 6, 2004 | 08:06 PM
bonez's Avatar
Default 2wd 4wd flashing
New 700 2wd 4wd flashing. Then the engine brake starts to engage and bike creeps forward. Tested everything and tests good. Swapped controler and kebc actuator, neither helped. HELP
Old Aug 6, 2004 | 11:46 PM
rolsmojave3's Avatar
never heard of this ahhh just take it to the dealer and if he tries to make you pay kick him in the teeth
Old Aug 7, 2004 | 12:06 AM
Nightryder888's Avatar
you have to count the seconds between the flashing
the chart in the manual shows each light staying on for .5, 1, or 2 sec. depending on what is wrong. a full cycle is double the length of a flash, i.e. if both were malfunctioning then the cycle would be 4sec. long (the time it takes the 4wd and 2wd to alternate)
if it is flashing every:
.5 sec = 4wd
1 sec = engine brake actuator
2 sec. = both
Old Aug 7, 2004 | 01:21 PM
DirtyWhiteBoy's Avatar
Try pulling the fuses, cleaning them, and reinstalling with some dielectric grease. The fuse block has a tendency to collect mud and dust. Once the KEBC fuse gets dirty it cuts the circuit and creates the flashing.
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
exmotocrosser
Sep 26, 2015 08:18 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
