Trouble after installing K&N Air Filter, HELP!
Old Aug 8, 2004 | 02:48 PM
FireFighter69ca's Avatar
Default Trouble after installing K&N Air Filter, HELP!
I put the K&N Air Filter in my P700 last night, went for a run today and had all kinds of trouble. First, going down the road at about 50 kph, hit the throttle and nothing, just bogged. Did this a few times. Second, going through a deep water hole, never got near the intake or the air box, and it just died, sounded like it ws running out of fuel. When I tried to restart it, it sounded like it flooded itself. Doesn't make sense. Any suggestions? I was wondering if I should rejet, if anyone thinks that could be past of the problem. I still have the stock jets in. With the old filter, never had a lick of trouble like this.
Old Aug 8, 2004 | 03:26 PM
therock's Avatar
To trouble shoot, put the OE filter back on and see if the prob goes away.
Old Aug 8, 2004 | 07:14 PM
bump
Old Aug 8, 2004 | 08:57 PM
NovaKaw650's Avatar
Well, did you try the OE filter? Result? Did you oil the K&N properly? The jetting shouldn't change that much with just a filter change, although with a modded muffler you would already be on the edge of needing to re-jet. Virually everyone with a modded muffler and an aftermarket filter has upped the jetting.
Old Aug 8, 2004 | 11:29 PM
I'm going on an 8hr run this weekend, with the club, I will take both filters with me and change them around to see if it makes a difference.
Old Aug 9, 2004 | 12:37 AM
crazyrc's Avatar
Is it possible you dropped any dirt into the carb. Changing an air filter will not give you the problems you described.
Old Aug 9, 2004 | 06:55 PM
I am sure I didn't drop anything in the carbs.
Old Aug 9, 2004 | 09:29 PM
Blastermaster's Avatar
i`d say you prolly neeed to re-jet, is the factory filter a foam one, if so the K&N will lean it out over a stock foam one, that is how K&N makes power by flowing more air into the cylinder, at the vary least i`d say go up one on the main, and changing out the pilots wouldn`t be bad either, the best thing to is go by the plug color, you are looking for a nice tan color, hope this helps
Jazperman
Aug 7, 2016 08:12 PM
toonces
Sep 5, 2015 01:14 PM
house1
Aug 9, 2015 10:49 PM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
