Anyone start BF with pull Rope?
Old Aug 12, 2004 | 02:42 PM
  #21
JoeMillionare's Avatar
Default Anyone start BF with pull Rope?
I really think you are doing it wrong.
I'm a small guy, 160lbs - and not alot of upper body strength.
However, i can pull start a BruteForce 750 on one pull.
Old Aug 13, 2004 | 06:55 PM
  #22
colmac's Avatar
I would have to see that to believe it.
Old Aug 13, 2004 | 07:11 PM
  #23
colmac's Avatar
Just went outside and started it dead cold on third pull. There is no way anyone can pull that thing over on compression stroke. I tried and ripped my freaking towel!!! you would think the user manual would go over that.
Old Aug 13, 2004 | 07:29 PM
  #24
Flareside's Avatar
Ok, here it is, but you may feel bad about your arm strength afterwards... [img]i/expressions/face-icon-small-smile.gif[/img]
Right click, then save as: http://silvervette.com:81/vids/MVI_1408.AVI
Barefoot, holding a camera in one hand, no towel. [img]i/expressions/face-icon-small-happy.gif[/img] http://silvervette.com:81/vids/MVI_1407.AVI
Old Aug 13, 2004 | 07:44 PM
  #25
See ! its easy! just make sure you have the crankshaft past both compression strokes-
(2 cylinder engine) then you can build alot of momentum with a full, firm pull.
Old Aug 13, 2004 | 08:06 PM
  #26
colmac's Avatar
ok downloading it now, what you have dial up??
S L O W...
Old Aug 13, 2004 | 08:21 PM
  #27
colmac's Avatar
ok, There must be something wrong with my starter cause even past compression stroke this thing is unbelievably hard to pull! I also feel a lot of tension on the rope as I pull it. I pulled it past the compression strokes and still it takes two hands to pull it. The rope is even starting to look worn from all the pulling I have done.
You look as though you are putting very little effort into the pull but mine has a LOT of resistance as I pull it. I feel as though it is going to break the rope there is so much tension on it.
Old Aug 13, 2004 | 08:42 PM
  #28
colmac's Avatar
ok, [img]i/expressions/face-icon-small-blush.gif[/img] I got it. I was pulling it to where it was 90 degrees to the engine instead of straight up. Once I pulled it straight up it came up so fast I about busted my hand on the left grip. I hope I didnt shorten the life of my rope now. It's pretty easy when you do it right [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Aug 13, 2004 | 09:15 PM
  #29
KawiTuner's Avatar
you think the brute starts hard you should try starting my friends p830.
It has 12:1 pistons and a bore and stroke of 87X70.
there isnt much chance in my 150 lbs starting that monster.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 13, 2004 | 09:34 PM
  #30
bombman's Avatar
adam will it be in washburn's pull.
