Brute force problems only 2hrs
Old Aug 15, 2004 | 09:36 PM
silverado's Avatar
Default Brute force problems only 2hrs
How many miles are on it?
Old Aug 15, 2004 | 11:27 PM
shaolinfox's Avatar
xcelr8 where are you in chicago,im south of you in monee.i have some buddies that ride at badlands and foxvalley off-road when you get your b/f 750 running right,we can let you know when we go next.. our rides are a 660griz,kfx700 yfz450,kfz400...
Old Aug 16, 2004 | 12:09 AM
Todd400's Avatar
Ran into the same problem on my new KFX 700 today sort of, After a few hours of playing I did a couple high speed passes and it started smoking, alot, after a quick inspection the airbox was filled with a few tablespoons of engine oil, after doing a little more checking and research I found that the crankcase is directly vented to the airbox and under high excelleration or steep hill climbs etc. if your crankcase is filled to the full mark it will SUCK oil from the crankcase to the airbox thus smoking like a sum b*tch for a minute or so and run like crap until it clears the oil, drain a little oil until you have your level in the middle between the hi & lo marks and this should solve your problem, if not you can route the crankcase vent to the bars with a check valve and solve it that way, but the adjusting my oil level has cured mine[img]i/expressions/face-icon-small-smile.gif[/img] Clean your airbox and filter too so you reference how if it has helped.
Old Aug 23, 2004 | 03:47 PM
BLOWNBF's Avatar
I HAD MINE FORE TWO WEEKS IT SMOKED A FEW TIMES THEN IT BLEW UP IT IS AT DEALER NOW LOOKS LIKE CRANK WENT AND SENT A ROD THRU THE UPPER AND LOWER OF THE CASE GOOD LUCK Text[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Aug 23, 2004 | 05:20 PM
  #15
MikeyBoyesq's Avatar
BlownBF,
I read in a magazine (ATV Action I think) that the BF uses a lighter crank than the Prairies. If this is true, I have to wonder if the BF cranks are more susceptible to breaking than the Prairie's crank.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 23, 2004 | 10:09 PM
  #16
xceler8's Avatar
Well got it back today, they claim there was water in the air box and mud that clogged the drain holes. The way the snorkle is set up, it seems any front end splashes will cause the airbox to grab water. The say its made to go in deep water but what at 2mph? Never had that problem on my prairie 700. I am going to have to check this out, because we do hard mud ridding and a machine that chokes out that easy isn't for me. i will continue on trying it and hopefully it was so freak accident. let me know how your guys brute does in the water.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
